GoldiesGarage
This will be my third body swap and I like using the old frame and then slowly replacing the body mounts with custom ones.
My rules for truck body swaps are
Frame - Fenders - Cab/body - bed
Frame - determines wheel base
Fenders - determines Cab/Body location, because the tires need to be centered in the wheel wells.
Body/Cab - determines bed placement.
Bed - gets shortened or lengthened. So tires are centered in the wheel wells.
Like I mentioned earlier I use the old frame to keep things together.
Once the tires were in the center of the wheel well and the body was eye-balled square. I welded the temporary brackets to keep it all in place.
Getting some measurements on where to cut
Test fitting and centering over tires.
I do not remember how much I cut off I think it was around 12 inches.
Getting it back together
And just like that the KB2-R was born. A 1949 International KB2 is on a 2014 Jeep Wrangler JKUR Frame.
Notes* With every abandoned project, the previous owners normally always give you a set of unforeseen challenges. In my case, this Gentleman welded the hood to the front fenders. I guess he wanted to do a tilt-front end. Also, he removed all the front fender mounting brackets, including some of the hood hinges. So my front clip just sitting on the cab and the frame.
