130 amp alternator and Sure Power 1314 100a isolator - Bad or ?
TheRedDawn
Hi -
My Tacoma has a 130 amp alternator.
I just picked up the Sure Power 1314 100a isolator.
Will my alternator send 130 amps to the isolator or will it be lower by the time it gets to it?
dwh
Tail-End Charlie
Your alternator will send whatever is being drawn from it. In other words, it doesn't "push", everything else "sucks".
So the question is: Will you have something that is sucking more than 100a *through* the isolator?
If all you are doing is charging an aux battery, you probably won't. But if you hooked up a winch to the aux battery, you probably will (when winching anyway).
TheRedDawn
I learn something new everyday..
Thanks for the info.
Just running lights, a fan, etc. basic stuff.
Thanks again. This forum is great.
Recommended books for Overlanding
Vagabonding: An Uncommon Guide to the Art of Long-Term Wo...
by Rolf Potts
From $13.33
Jupiters Travels: Four Years Around the World on a Triumph
by Ted Simon
From $17.48
Drive Nacho Drive: A Journey from the American Dream to t...
by Brad Van Orden, Sheena Van Orden
From $15.95
Overlanders' Handbook: Worldwide route and planning guide...
by Chris Scott
From $108.96
Road Fever (Vintage Departures)
by Tim Cahill
From $12.99
Antichrist
It looks like your alternator exceeds the capacity of the separator. You might want to check with Sure Power about the ramifications if your system is draws more than 100a.
