Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Vehicles > Domestic: Full Size and Other
Domestic: Full Size and Other Discussions specific to the modification and service of Hummers, GM and Ford large and mid-sized vehicles for Expedition Travel
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-21-2007, 05:27 PM
Carlyle's Avatar
Carlyle Carlyle is offline
Default Alaskan Camper Build Up
Hi folks,
I'm a refugee from the Expedition Camper forum who has been forcibly transferred over to this forum...Just joking!
I had a thread going on over there that was about the build up of my new camper. I will bring over pertinent parts of the thread to bring you up to date and look forward to your opinions and help:
Well here we go again... Our old slide in camper is trashing another vacation. We were on our way to the Oregon coast for two weeks of fishing and relaxation when our camper decided to shed a portion of its roof. Apparently after 3.5 years it is full of rot despite meticulous maintenance.
After much deliberation and talk to Bryan at Alaskan Campers we mailed a check off yesterday to secure a build time to start late October on a custom ten foot camper. We were planning on waiting one or two more years when we would have purchased an F550 to match, but I need my camper for work as well as play.
We are going to drop the pick up bed off our F350 and bolt it directly to a flat bed that we've not decided on yet other than length and width.
It's not a Hackney rig, but we have neither that time, expertise or money to invest in a camper of that magnitude at this time.
With that base we are going to add the following to start with:
Ten foot full-sided camper suitable for a flat bed truck. Standard flat beds are 82” wide with the camper being 82.5” wide.
Over cab queen size bed with extra insulation under the bed.
Rubber rub rail around outside of camper.
Standard 27 gallon fresh water, unless you can do a little larger with mechanical level indicator. Access hatch in top for cleaning would be nice.
Use Thetford cassette with handle for grey water. Shut off valve above cassette with hose attachment for dumping in sewer or boonies.
Extra Cassette with handle and wheels built into side storage with outside access.
We like the Thetford C-250 CWE model can you install it instead of your current model.
Standard propane furnace and catalytic heater plumbed and ready to hang. Please include and I’ll just attach when it arrives with camper to keep you legal.
Three way 5 cubic foot Dometic fridge with extra 12 volt fan for cooling. Must stay shut when bouncing around.
All double pane windows, including the over cab and cab pass through slide window.
12 volt/24 volt ac such as the DC Airco 8500 split unit: http://www.sunpowertech.com/commercial.htm or http://www.sunpowertech.com/commercial.htm
Electronic thermostat, Atwood or Dometic that controls both furnace and ac.
Two or three ICP solar fans in roof, one over stove and another in toilet area. http://www.solarcharger.com/s.nl/it....2&category=114
Built in 1500 to 2000 watt inverter to run microwave etc.
Battery status monitor such as: Sunsei Charge Controller CC-20000D for later solar add on.
Darkening blinds on windows such as: http://www.vehiclespecialty.com/pleated.html
Sirius antenna mounted to roof, I’ll send the antenna along.
Single large stainless kitchen sink with sprayer for faucet.
Propane hot water tank
Dometic CC05 Ceramic cook top stove with oven under. Built in low wattage microwave under oven if possible.
Three 110 and 12 volt receptacles inside and one of each outside. Additional outlet for future solar install.
36” chairs/couch facing each other in your front dinette model.
Spot to mount flat LCD TV facing one couch. Current LCD is 27” wide on articulated arm mount.
Reinforcement to attach our Carefree of Colorado Awning.
Camper outside corner reinforcement and plates to mount jacks if we decide to later.
Insulated inside battery compartment for four 6 volt gel cells. Warm batteries work better.
Outside hot/cold shower with marine quality fittings, our current one on the Hallmark is cheap and leaks.
Cabinets for cookware that hold plates and cutlery in place on rough roads. Smooth handles on all cabinetry.
High wattage back up lights on rear of camper.
Space to mount our car stereo style DVD player and Sirius player with 12 volt access near dinette.
Muffled or quiet water pump.
Propane and CO detectors running off 9 volt batteries if possible
__________________
'04 Ford F350 6.0 diesel slightly modified. 10' custom Alaskan on flat bed with a few add ons.
My camper build: http://www.expeditionportal.com/foru...ead.php?t=9502
KD0ERY
  #2
Old 11-21-2007, 05:41 PM
Carlyle's Avatar
Default
Haven, who is on this forum found this beauty:
I have this flatbed coming from the US dealer at an awesome price and should be here next week. The bed is sans the side rails and headache rack.
Thanks Haven!
__________________
KD0ERY
  #3
Old 11-21-2007, 05:47 PM
Carlyle's Avatar
Default
Charlie, another member of this forum advised the following:
If you are planning long trips, especially out of the country, I'd consider diesel powered heat/hot water, leaving propane for just the stove.
My response:
Thanks for the diesel advice, but after pondering and reading and many articles and peoples' discussions on the forums I decided to go with propane.
1. Sounds like propane is available down south even if you have to use a small local tank. widely available in Canada and the US. In addition, less used in warmer climates
2. Water heater and stove will be propane, with a forced air propane furnace and catalytic heater.
3. Diesel heat is expensive and not set up easily.
Hopefully this is not a mistake...
__________________
KD0ERY
  #4
Old 11-21-2007, 05:58 PM
Carlyle's Avatar
Default
Fisher29er, not on this forum advised me to go 12 volt on the fridge and have gone with a Novacool 5.7 liter fridge/freezer with the Danfoss compressor:
This is being mounted by Alaskan with extra insulation around the whole thing for greater efficiency.
__________________
KD0ERY
  #5
Old 11-21-2007, 06:00 PM
Carlyle's Avatar
Default
Why are we switching campers, here is the response I posted on Expedition Campers:
After touring the Alaskan factory last year and viewing the Alaskan campers compared to the Hallmark I would have to say that there is a significant difference in the quality and workmanship that goes into each. The old camper is simply not holding up the way I expected it would. I have had major problems with the lift system from day one and believe that it is simply not doing a good job. I have a longer Hallmark and the rear of the camper needs to be supported by 2x2's in the inside rear corners to keep it from drooping when in the up position. The rear of the camper goes up slower than the front and the edging of the roof seems to catch and that is probably the reason the water got into the roof. Every time the roof goes up and down it bends the front edging and eventually broke the plastic corners, twice now in fact. In addition the side fabric has been ripped in several places by the twisting as it goes up and down. The lift bars on my camper have been replaced twice now and I'm sure it is just a matter of time before they fail again. We had Yakima tracks put on at the factory so that we could put our tandem cycle and ocean kayak on top with Hallmark fully knowing and supporting this. The additional weight caused catastrophic problems and I feel we are now paying the price.
I have considered replacing the roof at $4k, but hesitate to put any more money in this camper as it does not meet our needs.
__________________
KD0ERY
  #6
Old 11-21-2007, 06:11 PM
Carlyle's Avatar
Default
Extras just sent to Alaskan to fit on during the build:
Satellite Radio Antenna
Wifi Antenna
I'm having Alaskan build three of these solar fans into the roof:
AC is a must in hot climates, but I want it off the roof and low consumption that can run off the batteries when driving down the road. Recent anti-idling laws for semi trucks has expanded the AC market. We really like this unit from DC Airco that mounts on the rear of the camper:
__________________
KD0ERY
  #7
Old 11-21-2007, 06:12 PM
Carlyle's Avatar
Default
Initial floor plan sent by Alaskan:
__________________
KD0ERY
  #8
Old 11-21-2007, 06:16 PM
Carlyle's Avatar
Default
The propane for the camper will run off a tank mounted below the deck and will look something like this:
Joaquin Suave added this tip about propane tank mounting:
If you are planning some 3rd world latin America travel, I'd opt for removable aluminum "forklift" tanks (plumbed for vapor) over fixed tanks for 2 reasons.
#1: There are more fill stations that are designed for walk up over drive up.
#2: We have found that when "hanging out" at a remote surfspot / beach, it is not un-common that another camper will be taking the looooooong trek into town to resupply & will gladly fill your propane tank (for a case of beer), thus making it able for you NOT to break camp.
I made this modification on Casa a few years ago and am uber-glad i did! Here is the 4wd link to the Casa remodel.
http://www.4wdtrips.net/forum/showth...ight=casa+azul
I'm still up for debate and may try a Casa-Azul style tank yet.
__________________
KD0ERY
  #9
Old 11-21-2007, 06:27 PM
Carlyle's Avatar
Default
Another tip added by Joaquin Suave
I wanted to share this idea with you, it a little "out of the box" so hold onto your chair...
since your are having your flat bed built for you, why don't you build the flat bed so that it is aprox. 16" from the back of the cab. in the gap between the cab and camper you can build a swing down tire carrier like on the military LMTV's on one side, a rack to hold a vertical propane tank in the middle, & storage on the other side for pioneer tools, buckets, mud boots, & other "need to be stored outside" stuff (like dirty laundry).
If your were planning to do a rack over the cab, the stuff I was talking about could be incorporated nicely into the back of the exo-frame. If it were me, I'd have the rack / tire carrier fab'ed out of oval aluminum and powder-coated to match the shape / profile / color of the camper.
The down side of this idea is:
*reduces your departure angle.
*makes it hard to have a crawl through.
*it will look a little odd.
The up side:
* It will buy you WADS of storage space.
* It will make managing a tire change a dream.
* It will make it able to have a removable propane tank (but fillable when mounted)
*It will provide cab protection in the case of a roll-over (especially if you did the exo-frame cab rack)
*It would provide very good protection for the propane tank.
*It would look VERY Expedition Camper-esque.
After much deliberation I'm going to pass on this idea, for now...
The F-350 chassis is just not heavy enough to mount that style of extra storage on safely. Our next truck will be a F-550 that will be more than adequate for this style system. The current camper and bed should transfer over nicely with limited modification.
__________________
KD0ERY
  #10
Old 11-21-2007, 08:20 PM
OutbacKamper's Avatar
OutbacKamper OutbacKamper is offline
Default
Hi Carlyle;
I am really interested in this thread. As you may recall from our previous discussions, I plan to do something similar myself eventually.
Here are a few questions, if you don't mind:
Are you definitely going with the DC Airco a/c? If so I will be eagerly awaiting more info.
Are you going to install storage boxes under the flatbed?
Since your flatbead does not have a headache rack, what prevents the camper from hitting the truck cab when loading ?
How is the camper going to be attached to the flatbed, and are you allowing for any flex?
And lastly (ok you knew this was coming !) how much is the complete rig (truck, camper, flatbed) going to WEIGH?
Cheers
Mark
Reply
Tags
camper
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
