| Communications: HAM, CB, 2M, SAT Discussion of communication systems as they pertain to expedition travel. |
Thread Tools | Search this Thread | Display Modes |
#1
My personal policy is as follows:
I usually key up and say: "KE7IXX would like to access the IRPL node in appoximately 60 seconds. Is there any outstanding traffic on this repeater?" I listen for the full minute, and if it's clear, say: "This is KE7IXX controlling IRPL Node (XXXX) in (XXXXXXXX)" and while still transmitting type in the node number and then release the key. After the node connects, pause and listen for traffic on the node freq. When clear, make your call. Remember to pause before speaking - key up wait for one or two seconds before speaking to allow the connections to be made. Also, wait for any squelch tails to drop before keying up after the last transmission. When you've completed your call always thank the node owner for the useage before closing, even if you are part of the club that owns the node. While still transmitting type in 73, and release the key. More info - excerts from: http://www.narri.org/IRLP.html Quote:
__________________
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." Last edited by crawler#976; 10-10-2007 at 05:33 PM. |
#2
Great information, can we make this a STICKY?
__________________
Dave, Yoshi and Dixie [KI6LBB] The Adventure Duo 2004 Jeep Wrangler TJ X Edition 1993 Toyota Landcruiser 80 Series 2004 Adventure Trailer Horizon www.caltape.com Need digital media? www.trasharoo.com Pack it in Pack it out! |
#3
Great info. I was able to connect to the west. ref. today. I look forward to meeting the group.
__________________
Guy ( KI6LHZ ) 1989' Fj62 Restoration project 1999 100- Partially Kitted. |
#4
A question for anyone who knows about reflector use.
If you conect to lets say 9250 and then decide you want to connect to 9251. Do you have to disconnect from the node and start again, or is there a way to re-key in the next channel? Thanks in advance
__________________
#5
Quote:
#6
Yes, you must terminate the link. Think of it as opening a web link - because that's essentially what you are doing.
__________________
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." |
#7
I am still planning on making the connection to the western reflectror via a repater on Sandia Crest in Abq and I have a newb question. If I get this to work and I get connected, I'm no longer broadcasting off the local repeater right, at least out where the local hams can hear?
If I am having a QSO about fridges or whatever from Sandia Crest through the reflector, is it being repated locally? If not, then once I'm in a node and no longer repeating out locally, then can the repeater still work for local traffic? I'm having a hard time wording the questions because I'm confused about some of the details. Thanks. |
#8
Chuck, anyone that can hear your local repeater will be able to hear and participate in the conversation you link to via IRLP. The repeater works exactly as it did before, but is linked to another location via the internet.
That's why it's important to follow the procedure above: Quote:
I usually key up and say: "KE7IXX would like to access the IRPL node in appoximately 60 seconds. Is there any outstanding traffic on this repeater?" I listen for the full minute, and if it's clear, proceed from there. Even tho I'm a club member of the nodes/repeaters I use ($20.00 a year for three local groups is no big deal, right??? They have to pay for the equipment and internet access somehow... YARC just bought a Kenwood 2M 60W repeater for a little more than $1100.00 for our use - that's a lot of $20.00 dues.) I don't want to be an airwave hog, and being courteous is key to being able to use the equipment... Mark
__________________
#9
Thanks Mark,
I've always been the kid who didn't raise his hand in class. So, having my chat beamed halfway across NM is a mental hurdle for me. I do plan to try it out though at some point. From my house it is ~60 miles to the repater, I will probably have to wait for a trip to Abq to test this out. Thanks. Chuck... Quote:
#10
Mark this is great advice. I didn't relize I took over the repeater when I linked up.
__________________
| Display Modes | |
