Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Vehicles > Toyota: Land Cruiser: Sponsored by TLC
Toyota: Land Cruiser: Sponsored by TLC Discussions specific to the modification and service of Toyota Land Cruisers for Expedition Travel. Sponsored by www.tlc4x4.com
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 02-07-2007, 01:47 AM
Brian894x4's Avatar
Brian894x4 Brian894x4 is offline
Default Brian894x4’s Land Cruiser FZJ80 build thread.
Do you guys mind if I start my own build thread? This rig will be replacing my 1989 Toyota PU SAS and so over the next few months, I'll be modifying it to fit the role that my truck has so faithfully served us for the last 7 years. The '89 truck will be hearafter known as our "legacy expedition rig" and it will be prepped and put up for sale very shortly to clear garage space for the new expedition rig.
The new expedition rig is a 1995 FZJ80.
Initial specs are:
1995 FZJ80, all stock
No lockers, but has at least an ARB rear in it’s future.
85,000 miles.
Previous owner just installed brand new 275/70R-16 BFG A/T KOs a few months ago.
Locally owned rig, I’m the 3rd owner. Two prior owners were ladies. First one rarely drove it and barely put 6000 miles on it a year. Second one drove it as a commuter car.
Color is Moonglow Pearl, which is a fancy way of saying bluish/gray.
Original purchase price in 1995 was $48,000
It’s very clean and almost in perfect condition. The only negatives are that the leather has sort of cracked, but not ripped. I’ve since conditioned it and that actually made some dramatic improvement to the point that I think it’s savable. The other issue is that there’s a very slight leak from the rear of the engine, that could be a rear valve cover leak or could be a rear main seal. If it’s the latter, I’ve been told that rear main seal leaks are very common on FZJ80s and that I could probably just live with it for most of the engine’s service life.
There’s not a spec of rust anywhere and besides the clean interior and exterior, even the underside is fairly clean indicating that most of it’s usage was on paved roads.
Here’s some initial pics. The very first thing I did was remove the running boards that came with it and also the Toyota bug deflector (it was rubbing up against the hood and damaging the paint.). Also, the 3rd row seats were removed and all of the above will go into storage, since I don’t have much need for any of it right now.
__________________
Brian McCamish
In Search of History Expeditions
Gresham, Oregon
1995 Toyota Land Cruiser FZJ80 (new expedition rig)
1989 Toyota 4x4 truck w/SAS (retired expedition rig)
www.brian894x4.com (Homepage)
Our Land Cruiser FZJ80 Main Page
In Search of History Page
Abandoned & Active Railroads of the NW Page
  #2
Old 02-07-2007, 02:35 AM
CLynn85 CLynn85 is offline
Default
Oh Snap! Very nice. After seeing your PU I can't wait to see how this one comes out.
__________________
Carl
-98 Jeep - Sold
-2007 Tacoma TRD - New adventure toy and DD
  #3
Old 02-07-2007, 02:50 AM
Brian894x4's Avatar
Default
Until I can get the truck sold, the LC will have to sit outside for a while, so my intitial mods will all be low key so as not to draw attention to itself.
In fact, the entire build will be fairly low key, compared to the neon sign that is our truck. Much of our exploring and research involves parking our rig somewhere and hiking down a trail, abandoned logging RR grade or up a closed road towards a fire lookout or abandoned mine. The truck just screamed out "I have lots of goodies for the taking inside me!"
This build will make an effort to compromise having all the necessary accessories and mods, without looking like it's a super spendy truck worth breaking into or trying steal.
My planned approach is keeping the vehicle fairly stock looking on the outside. The notable exception will be an ARB bumper and winch and some sliders. However, there won't be a roofrack or tall lift or tall tires or snorkle.
I had debated the roofrack idea, until it became clear that I couldn't fit in my garage with one, even with stock tires and stock suspension, so that was an easy decision.
This theme will extend to the interior as well. My truck has a dozen gauges and 6 million switches, plus two GPSes, 3 radios and a laptop. A total theft magnet. On the LC, some of these items will still be needed, but they'll be hidden out of view. I already have plans to install my radios inside the center console and external antennas will be easily removable. The GPS will be mounted in such as way as it's easily removable and securable. Same for the laptop. Extra gauges and switches will kept to an absolute minimum, possibily utilizing factory switches when feasable.
I haven't quite figured out how I'm going to set up the interior. I want to retain the ability to carry 3 passengers and myself on a long trip (one major reason for upgrading from the PU to the LC) so the 2nd row seats will remain in place. My initital thoughts are to just carry my gear, tools and spares in easily removable boxes/crates, rather than build a permanant set up like the rear of my truck.
My wife and I are not tall and I think we could manage to sleep fairly comfortably in the back of the Land Cruiser if we pull our storage boxes and out and store up up front and/or outside/under the rig. It's certainly more roomy than the back of my truck ever was. We'll see. A rooftop tent might be in our distant future, as well.
To power everything, I plan on a duel battery system, similier to my truck, but MUCH simplier. I'll be mounting a second battery on the passenger side with a controllable solenoid to seperate the two batteries while the engine is off. For now, the stock alternator will remain. I believe it's 110amps, which should be enough for my needs. I may eventually upgrade, but will probably just stay stock and rebuild it for reliability.
As far as suspension/axle/tire mods. I'm still debating.
I'm fairly certain, I have no intention of lifting the LC. Certainly not significantly. Since this will be an expedition rig that will see 90% highway/dirt/gravel roads and about 10% moderate off roading, I don't see the need for anything taller than 33" tires. I anticipate at least having to change out the front springs to compensate for the ARB and winch and I like the OME's stock hieght kit which would be about 1" depending on weight. But I have research to do in regards to what springs would work the best for my application.
Once I settle on a tire size (I'm thinking eventually, 285/75R-16 MTRs should do nicely) then I have to make a decision about whether I want to go to the expense and hassle of regearing both axles. Once that decision is made, is when I'll add lockers. Either just a rear ARB or ARBs front and rear.
I have ton of little mods planned, like raising the spare, CDL switch, hand throttle, etc, etc.
I haven't had a chance to update my website, but the build will be documented there as well, a little more extensively.
__________________
Brian McCamish
Gresham, Oregon
  #4
Old 02-07-2007, 05:29 AM
adventureduo's Avatar
adventureduo adventureduo is offline
Default
Great looking 80. Perfect condition man. I drove to Sacramento from OC to get mine that condition.
I just recently bought mine in July and have been building it rapidly ever since for expedition use. I would love to see another FZJ80 build up. The 4.11's that come stock will be fine for what your using it for and that tire size. I've done the CDL switch and you'll love that too. Slee sells both the CDL switch and the hand throttle. Got my hand throttle on the way.
Keep us up to date!
__________________
Dave, Yoshi and Dixie [KI6LBB]
The Adventure Duo
2004 Jeep Wrangler TJ X Edition
1993 Toyota Landcruiser 80 Series
2004 Adventure Trailer Horizon
www.caltape.com Need digital media? www.trasharoo.com Pack it in Pack it out!
  #5
Old 02-07-2007, 09:51 AM
Brian894x4's Avatar
Default
I like your rig. Very nice. My dream set up. That's basically what I like to end up with in the end, rooftop tent and all. The rack and tent will be much further down the road, however. How does it handle with all that fuel and the tent up top?
CDL switch, 7pin mod, and hand throttle will be done very shortly since those mods are faily straight forward. Beyond that I have to get my truck ready for sale. But once the truck is gone and I can move the LC into the garage, things will start happening quickly.
At first, I said no lift, but now I'm leaning towards maybe an OME 2.5" medium load rear springs and heavy load front springs. Just to get things, like the cat converters out of the weeds.
__________________
Brian McCamish
Gresham, Oregon
  #6
Old 02-07-2007, 11:27 AM
calamaridog's Avatar
calamaridog calamaridog is offline
Default
Brian,
I'm going to say that 97% of people don't even see the improvements you will make.
Bling is NOT found on Land Cruisers.
Disable your truck at the trailhead and hike away. I wouldn't worry about it too much.
If the leather bothers you, there are replacements available.
Awesome truck. I look forward to seeing what improvements you make.
__________________
2002 Jeep Liberty Limited 4x4
OME heavy springs
Bilstein front struts and rear shocks
Yokohama Geolander AT-S 245 75r16
  #7
Old 02-07-2007, 02:20 PM
locrwln's Avatar
locrwln locrwln is offline
Default
I was going to suggest the lift springs just for the ride improvement. It's hard to believe, but mine rides and handles better with the OME mediums. I still don't have a front bumper or anything, so I didn't need the heavy front springs.
The stock gearing is fine for 285's, so no need to worry about regearing, I did get the Speedo correction gear from Slee for the tranny shift points.
Can't wait to see the build, mines been slow in the making, but handles all of the desert and long road trips, loaded, that I have done. I just got my sliders done. My next big thing is working on a auxillary tank for more range.
Jack
__________________
1996 Toyota Landcruiser (explorer)
2002 F350 (hauler)
1995 MX6 (speedster)
KE7NCK
  #8
Old 02-07-2007, 02:34 PM
DaveInDenver's Avatar
DaveInDenver DaveInDenver is offline
Default
I won't go so far as to say you /never/ see bling on a Cruiser, but the sort of stuff we hang on our trucks I think makes them look less attractive rather than more. For one it makes them unique and stand-out, something that is bad for a would be thief.
Otherwise Drexx is about right on. Add a couple of defeats to make it difficult and just be happy. I put in a Tuffy center console in my Hilux and if they can get in to that quickly and quietly, they deserve whatever's in there. As far as radios, I wouldn't worry. They are after car stereos. CB and ham radios are hard to pawn (and anyone who's savvy enough to recognize a ham radio isn't a CB is probably not gonna be stealing radios) and so they are less likely to be targets.
This is not to say you shouldn't be careful leaving your truck at a trailhead, but basic precautions. It's not so much vehicle theft as content protection. It's pretty common around here to have theft at well known trailheads. This is primarily because the bad guys can watch and know you'll be gone for a certain amount of time. So locking boxes and covers to keep things out of sight are key. They are looking for an opportunity and if all they see are Tuffy boxes or wood boxes with padlocks with nothing interesting sitting out, they are more likely to pass your truck over.
__________________
1991 Toyota RN110 (Imelda the Rubicon-proved Hot Rod IFS Hilux)
1992 WilderNest Adventure Camper
TLCA# 10427
"If you want to know who is going to change this country, go home and look in the mirror." --Maude Barlow
  #9
Old 02-07-2007, 03:31 PM
expeditionswest's Avatar
expeditionswest expeditionswest is offline
Super Moderator
Default
Congrat's Brian. You now own one of the greatest vehicles ever brought to the US, and with low miles too.
I really like the mod concepts and keeping things simple. Even without lockers the 80 is amazing on the trail.
I would consider an OME suspension, mostly to accomodate the loads and limit head-toss. Consider a 275/75 as a replacement too.
  #10
Old 02-07-2007, 03:57 PM
kcowyo's Avatar
kcowyo kcowyo is offline
ExPo Original
Default
Congrats Brian!
I really like the color you found. I'm a big fan myself of understated but highly effective mods that don't draw attention. Under the radar is a good place to be.
I look forward to seeing your build. Hopefully you'll be able to figure out an ideal rear storage solution in less attempts than you did with your truck.
And you realize this is going to completely screw up your whole "Brian894x4" thing, right?
__________________
'97 Toyota T100 - some stuff and some stories....
'85 Toyota FJ6O - fractal cruising
currently listening to - Lucinda Williams "Little Honey"
recommended reading - Lone Survivor by Marcus Luttrell
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
