Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Vehicles > Domestic: Full Size and Other
Domestic: Full Size and Other Discussions specific to the modification and service of Hummers, GM and Ford large and mid-sized vehicles for Expedition Travel
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 02-01-2010, 05:51 PM
Rot Box's Avatar
Rot Box Rot Box is offline
Thumbs up My crew cab IDI Alaskan Camper build
This has been a decision that has taken me a long time to make. After finally realizing that there is not nor ever will be one single vehicle that suits all my needs I had to make some compromises. In the long run I need something that both my family and I could take exploring for long periods of time and still be able to drive some somewhat difficult trails in poor weather conditions. While many vehicles can do all this and much more there are a few items that I needed in specific that really narrowed down my search. Here is a list of things I needed when I was searching for my last truck.
4doors—must have.
Ability to tow a large load safely
Manual transmission
Simple engine design (mechanical injection or Carburetor)
Cost less than $7K and model had to have a long production run.
Strong drive train.
Ability to carry a Camper. (Alaskan, Flipac or just my RTT)
Return 15mpg or better unloaded.
Minimum 450+ mile range on stock fuel system.
Truck: What I ended up with was a crew cab 1991 Ford F350 with the mechanically injected 7.3 IDI International diesel engine and a ZF 5speed transmission. This truck has the solid Dana 60 in the front along with a Sterling rear axle both with 4.10 gearing. I have owned several IDI Ford diesels and although they have some quirks they prove to be extremely reliable and durable—they are built to work hard. I like these because they require one wire to run, will burn many different fuels and because Ford sold so many F-series trucks these years and International sold so many engines parts for both are very common and not too expensive.
Camper: Although I have wanted one for quite awhile this Alaskan fell into my hands much sooner than I had anticipated. It is a 1971 Fiberglass Alaskan 8’. Aside from it being 40 years old it is in very good shape and still has the features that make Alaskan’s desirable. Strong construction, pop top and very thick insulation make these great for backcountry exploring and cold weather camping. They weigh in at ~1100 lbs.
Plans-short term: For now there are a lot of modifications I need to do to the wiring and heating so I’m going to start with the needed items and work my way into accessories. I am hoping to have the heater and stove working and the water system working in time for April. The truck needs new tires too so I’m leaning towards BGF KM2 255/85E 10ply’s.
Goals short term: In April we are going through the San Rafael Swell down to Arches and my wife hasn’t ever been to So. Utah so this should be a lot of fun. We also have many local camping trips planned this summer along with a trip to Yellowstone/Grey’s river area.
Plans-long term:
Onboard air. I’ll probably go electric on this one.
Solar DC charge system. I am not going to tie the camper power in with the
truck which means I have no easy way to charge the batteries while out and about. The truck needs all the power it can get from the two batteries it has just to crank the engine over so I don’t want to take away from that.
Lockers in both axles. Detroit rear selectable front.
Sliders (really really long sliders).
Winch/winch bumper. 12K lb or higher. Aftermarket bumpers are big $$$ so
I’ll try to build and mimic an ARB Bull Bar when I get the time.
Low profile flat bed. These just work so good with off-road campers. I could put all my air tanks, propane and other things under the platform up and out of the way.
Modify departure angle. I already removed the spare tire and brackets now I need to do something with the rear bumper and receiver hitch. May install a non step bumper from a bronco and see how that works out for a quick fix.
Goals long term. Although my last trip fell through I still want to tour Alaska bad—really really bad. Maybe one day I can make it up that way.
Anyway I don’t expect this to be a quick buildup by any means, but I will post up any progress as it comes
__________________
71-Alaskan Camper. 8ft. Fiberglass.
81-Four Wheel Camper FWC
91-F350 crew cab, 7.3IDI-ATS 088-ZF 5speed
79-Toyota Hilux 20R 4x4.
My Gypsy wagon buildup: http://expeditionportal.com/forum/sh...ad.php?t=38047
  #2
Old 02-01-2010, 05:58 PM
Rot Box's Avatar
Default
This week I'm hoping to pull down the bulky AC unit and plumb in my propane tank under the truck bed. I can't think of a time when I would ever need AC and this thing is just way too big
__________________
  #3
Old 02-01-2010, 08:47 PM
Sock Puppet's Avatar
Sock Puppet Sock Puppet is offline
Default
Excellent choice and a great project! I would also consider having the camper battery tied into the truck's charging system with a marine battery switch. This would allow you to charge your camper battery while traveling, and isolate it when starting the truck.
  #4
Old 02-02-2010, 04:55 AM
Rot Box's Avatar
Default
Thanks for the reply!
I explored my solar charge system idea with a friend at work tonight (His house is completely solar powered ) and quickly determined it is just not cost effective for what I plan to do. Great idea on the isolator that will probably be my best bet for sure.
I'm still kind of new to the camper thing but I'm really getting some great ideas searching around on Expo. Anyway I guess me saying build was a bit of an exaggeration, but I'm sure having fun--can't wait to try it out
__________________
  #5
Old 02-02-2010, 02:49 PM
ntsqd's Avatar
ntsqd ntsqd is offline
Default
The problem with the marine switch is that is keeps the batteries in parallel all of the time. Running down your house battery(ies) will also run down your starting battery(ies). There are a lot of automatic options available. Fortunately we have this resource: http://www.expeditionportal.com/foru...splay.php?f=48
__________________
I used to swerve around my hallucinations, now I drive right through them.
  #6
Old 02-02-2010, 04:27 PM
MATTY291 MATTY291 is offline
Default
Looking forward to this build. Nice truck & very cool camper!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
