| Power Systems: 12v, Solar, Gen. Discussion of auxiliary power systems as they relate to expedition travel. |
Thread Tools | Search this Thread | Display Modes |
#11
National Luna all the way...
__________________
James - KC2SYG ------------ 2008 Sportsmobile RB50 2005 Jeep LJ Rubicon 2010 Ford F150 Raptor 2010 BMW R1200GSA 08 KTM 990 Adventure 06 KTM 640 Adventure www.trailmonkey.org |
#12
Quote:
Wiring diagrams, parts lists, more photos, etc available if this looks like it might work for you.
__________________
2006 Tacoma TRD 4WD w/Access Cab/Rear Locker/Tow Package/Leer cab-high cap/Bilstein 5100s x4/Deaver 10-leaf springs/Ride Rite Air Bags/Demello Rock Sliders/Goodrich AT KO/Aux 12VDC system front and rear/2m+70cm+CB comms/GPS+Nav laptop/fridge Last edited by Michael; 01-06-2010 at 03:54 AM. |
#13
Very nicely done !
Thanks for posting that. How do you think that going the DIY route compared in cost to say the NL set-up ? Frank |
#14
Quote:
I will say I went with the Hellroaring not because I found anything negative about the National Luna but that the kit did not suit my needs. That being, I had no use for the cabling provided and preferred to purchase everything separately. Regardless of which unit you go with, do read through the FAQ's at Hellroaring's site if you haven't already done so. Particularly the diagnostics available. He gives a lot of good basic info about setups in general like having your better battery as the backup. News to me. Speaking of my setup, I always have a surface charge indication at my remote switch and can take my main battery out and crank my engine through the unit and a total of 20' of 2 AWG in winter. I did this for about two weeks last winter while I was shopping a new main battery. Check in the box. The more you dig into this, the more questions you'll have, until you bump into the engineering side of things and either cry uncle or learn math. |
#15
so i spent lots of time reading today about this and even called hellroaring (very nice and helpful on the phone).... here's what i come away with for those that may want lots of info before making a decision:
there are 5 types of battery management systems that i count... 1. a manual high-current switch with A/B/BOTH selectors (a "boat switch") - there are no "smarts" to the system, it only does exactly what you tell it, this can be good and bad (good that you have full control, but bad as you could leave it set to "both" and leave something on thereby depleting both batteries and having no backup)2. a "boat switch" and a battery isolator (such as from sure power or perfect switch) - all the same characteristics as just a "boat switch" but without the worry of one battery "bleeding" the other, the batteries are isolated in that only charge current goes to both of them, but no current transfers between them3. an intelligently controlled solenoid system (national luna or IBS for example) - in this case a solenoid (high current relay) acts as the "boat switch", except in all systems i know of, you only have "A" and "BOTH" settings. the big plus is that you run a small cable to a remote controller to set the state of the solenoid instead of having to run giant cable in order to relocate the "boat" switch (and the solenoid stays near the batteries).4. in intelligently controlled digital switch (hellroaring for example) - pretty much the same as the intelligently controlled solenoid except that the solenoid is replaced my a modern digital switch5. some "i did it this way" method that use pieces from the above types of systems - i guess the ultimate system would be to use 2 digital switches (probably from perfect switch, as they supposedly have the best digital switch) and your own custom microcontroller that would allow you to have all the system sensing and control qualities of national luna/IBS/hellroaring products, but with a "B" setting too (instead of just "A" and "BOTH"). add to that your own digital voltage readouts of both batteries and custom control panel with override switches and timers and audible alarms.more reading: http://www.nationalluna.com/DIY.htmso what am i going to do? well i'm about a month or so from actually finishing up my battery relocation project and therefore being ready to purchase a system. i'll have to look at my funds when the time comes. i won't do a "boat switch" based system because my batteries are going in my spare tire well in the trunk and i don't want some janky looking giant switch run into the cab, i want a clean remote control.please add to this if any of my facts are incorrect, otherwise most things are just my opinion... your mileage my vary.
__________________
* 2003 WJ, 6", Clayton Long Arms, 33" KM2's on 17" Eagle Alloys * 2006 Suzuki DR-Z 400 S Last edited by theksmith; 01-07-2010 at 01:54 AM. |
#16
I have been running the National Luna for about 2 years with absolutely zero problems. I will qualify that by saying, you need to monitor your system and keep track of battery management. Don't let them run down too far, Plugging my frig into A/C when using it for extended periods at home. I have a CTEK Charger conditioner permanently mounted and wired in to maintain battery health . It's actually very little work. You just need to be aware of your conditions and workload.
__________________
www.wikidfj.com under construction |
#17
For what it's worth I had a sure power smart solenoid battery interconnect thing in my 95 Range Rover. It sounded like the perfect solution because I wanted to use my batteries together but I wanted to be sure that I always had at least one for starting.
I had it installed for about a year and during that whole time I had the weirdest electrical gremlins ever. Things like the entire electrical system shutting down for a second while driving down the highway and things like that. Being a Rover owner I took it in stride as kind of "normal" until I decided to pull that thing out and see what happened. After that everything has returned to normal. It's probably just a Rover thing. It's for sale if your interested.
__________________
Noah - KL2UD |
#18
Quote:
Great job - this is the best explanation I've had of all the systems together. Thanks for your initiative!
__________________
2001 Tacoma Extended Cab, 3RZ FE, AT, 5.29 gears, ARB rear locker, 4WD, ARB front bumper, Warn M8000, Demello sliders & rear bumper, Iron Pig Offroad rear bumper mounted tire/Jerry can carrier, BudBuilt skid and belly pan, snorkel, Can-Back, OME/Dakar suspension, LC80 wheels, 285/75/16 BFG MT, and a few other mods |
#19
The combo that I prefer is a "smart" solid state relay combined with the 'boat' switch, which is a variation of one of your list items. Sized correctly the boat switch can handle full starting or winching current (up to 1000 amp surge is not an unreasonable switch capacity) and the "smart" SSR will handle the charging function independent of the boat switch's setting (excluding a "both" setting as then it is redundant).
There are single sensing and dual sensing "smart" SSR's available. The former only senses the Aux battery's state of charge while the latter senses both and discriminates. AFAIC diode bridges ("battery isolators") have no place in a vehicle's battery charging system. They can be made to work, but that requires a customized alternator. Something that I see no point in as it makes field repairs or replacement a problem.
__________________
I used to swerve around my hallucinations, now I drive right through them. Last edited by ntsqd; 02-27-2010 at 07:47 PM. Reason: typo |
#20
Quote:
Taken directly from NL's manual - "When active, the “TIMER OVER-RIDE” light will flash and will remain active for 5 minutes only. Use the same procedure to de-activate the timer “over-ride”." Oh yeah - and after actually "reading" the operating instructions for the first time.......a few minutes ago (oops ), I noticed that they say to not instantly try to start the the truck off the reserve battery in the event that the primary is dead, because it could result in blowing the systems in-line fuses. They say to wait a few minutes after hitting the over-ride button and allow the reserve battery to charge the primary. Well I can tell you from experience that the fuses will not necessarily blow because I've had to jump myself off twice.............due to accidentally leaving the ignition on all night after working on my truck (getting old and forgetful sucks !) and as soon as I hit the over-ride I cranked the truck right up both times.........
__________________
'01 Tundra / '08 Tundra My Junk - http://community.webshots.com/user/0...host=community My Build Thread - http://www.expeditionportal.com/foru...ad.php?t=18722 Last edited by 01tundra; 01-07-2010 at 06:32 PM. |
| Display Modes | |
