b jeepin
This tent was one of the most cost affective options ive come across so far. the tent is not designed for use as a rtt but is easily adapted to work if you have the right dimensions. this particular setup is a two man cot tent. designed to keep you off the ground in this case way off the ground. i recently purchased this guy gently used and so far i love it! i still need to fab up a ladder because it is not all that easy to get in and out of. i have this mounted right now to the factory rack on the jeep, i plan on installing a custom rack in the near future. these tents can be found at some retailers in certain areas or search online for a cot tent. these can be purchased for less than 300.00! it definately will take more time to figure out mounting, height restrictions, a ladder, a cover, etc. but is quite comfy and i'll add more updates on how it holds up soon! thanks for your interest, Brad. cheapthrillsoffroad
:1888fbbd:
