Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Vehicles > Toyota: Land Cruiser: Sponsored by TLC
Toyota: Land Cruiser: Sponsored by TLC Discussions specific to the modification and service of Toyota Land Cruisers for Expedition Travel. Sponsored by www.tlc4x4.com
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 04-06-2008, 01:24 PM
Brian894x4's Avatar
Brian894x4 Brian894x4 is offline
Default Rear View Camera install, w/pics
I’ve been wanting to try out a back up camera system for a while now, but it wasn’t until I saw one the other day, that I sort of had this impulse to really give it a try.
I looked around at a bunch of different systems. Including some camera/LCD combos and separate camera and LCDs. You can really spend some cash on this stuff if you want too. But the one problem I had with all of the set ups, is that I didn’t really have a place to mount the LCD, which usually was meant to go on the dash or flip down from the ceiling.
There was one set up that really caught my eye. It’s from Audiovox (The kit is Audiovox RVMPKG4) and essentially replaces your rearview mirror. Or more accurately straps over it.
The result is a large standard looking rear view mirror, when the system is turned off, and a 4.5” LCD screen in the mirror, when its turned on.
What I like most about this set up is, that there’s no LCDs in the vehicle to attracts thieves (not that I don’t enough other garbage to attract them instead) and it looks like a stock mirror at first glance. But even better, the location of the LCD is very natural, since we’re all used to looking in the rear view mirror to see what’s behind us anyway.
Set up is not super fancy, but it does have a few cool features. The LCD is a 4.5 TFT screen 480x234 resolution at 4:3 ratio. Definitely not the highest and its not widescreen, but it works. The constrast ratio is fixed at 150 to 1, but the brightness is adjustable via a dial on the mirror.
The camera is ¼” CMOS Sensor, color, same resolution as the screen with a wide viewing angle of 130 degrees. There are definitely better cameras out there, but I’m fairly happy with it. It’s pretty heavy for its size with a metal water proof housing. Minimum illumination is .3 Lux.
What’s interesting is the camera comes with a built in microphone and the mirror has a speaker, with a volume dial. This is meant to allow you to hear people or kids behind the vehicle before you back up. It actually works pretty good. For example, I could hear the exhaust turbo like whistle going down the road (bear in mind, my exhaust is stock and in good shape). Of course, it’s not meant to be used while driving and I just leave the volume down, unless I need it.
The LCD can toggle between two cameras if you have a second one. I bought a second one with the intention of mounting it up front and down low for better off road visibility, but I nixed that plan and instead mounted one camera up high on the roof rack and the other down low just above the license plate. This gives me two different, very useful rear views.
The kit is designed to come on automaticly with the reserve lights and only come on with the parking brake on…so you can’t watch the video while in motion. Of course, I didn’t wire it up that way, because I want to be able to use it while driving and especially while backing up. Instead, I wired it so that it has power with the ignition on only and then, you can toggle the on/off switch on the mirror as desired.
Pic one: Shows the two cameras mounted. One on the roof rack and one just above the license plate, under the license plate light hood.
Pic two: Shows the upper camera
Pic three: Shows the lower camera
Click image for larger version
ID:	17614   Click image for larger version
ID:	17615   Click image for larger version
__________________
Brian McCamish
In Search of History Expeditions
Gresham, Oregon
1995 Toyota Land Cruiser FZJ80 (new expedition rig)
1989 Toyota 4x4 truck w/SAS (retired expedition rig)
www.brian894x4.com (Homepage)
Our Land Cruiser FZJ80 Main Page
In Search of History Page
Abandoned & Active Railroads of the NW Page
  #2
Old 04-06-2008, 01:25 PM
Brian894x4's Avatar
Default
Pic one: Shows the mirror/LCD with the LCD off. You can use it just like a regular rearview mirror, although it’s a tad darker than the stock mirror. It's larger than the stock mirror and actually increases rear visibility even with the LCD off.
Pic two: Shows the mirror from the side. It just straps over the front of the stock mirror, but is actually pretty secure.
Pic three: Shows the bottom and buttons. The two dial buttons on the bottom control LCD brightness and volume of the speaker. Button 1 is the power on/off toggle. Button 2 toggles between the two cameras. The speaker is on the backside of the mirror.
ID:	17617   Click image for larger version
ID:	17618   Click image for larger version
__________________
Brian McCamish
Gresham, Oregon
  #3
Old 04-06-2008, 01:26 PM
Brian894x4's Avatar
Default
Pic one: Shows the LCD turned on inside my garage using the lower camera.
Pic two: Shows the LCD turned on with the brightness turned down slightly and my rear lights turned on, on a dark country road, using the upper camera. (so far I’ve only used it at night)
Conclusion so far….
At night, especially with the aid of street lights, the visibility to the rear is just staggering. Far better than without. On a dark road, turning on my (not so bright) rear lights and I can see as if I were looking down the road using headlights.
As far as driving at night with traffic headlights behind you, I prefer to leave the LCD off and just use the mirror, because the lights end up being too bright on dark roads. Not so bad in the city.
Backing up using the camera is much easier now. Especially when combined with the side mirrors. I could literally drive backwards without ever turning my head. The whole point of the system for me is backing up on a trail or old road and here is where it will shine the most. You still need to use the side mirrors to judge the sides of the road/trail. The wide angle of the camera and the essentially 2D view give a false depth perception, so the camera can't be used on its own to back up, but it sure makes things a lot easier and safer.
The screen and camera resolution are only OK. There are better cameras and better LCDs out there. Not sure if any of them use this mirror style or not. So far, I'm pretty happy with this set up. Its simple. Not a lot of frills, but it works. And whoever came up with the idea to mount a rear view camera LCD into the rearview mirror deserves major kudos, because it just makes perfect sense.
__________________
Brian McCamish
Gresham, Oregon
  #4
Old 04-06-2008, 02:18 PM
targa88's Avatar
targa88 targa88 is offline
Default
Brian,
Great write up and pix.
Where did you find the Audiovox kit?
  #5
Old 04-06-2008, 07:29 PM
Brian894x4's Avatar
Default
Thanks much. My local Circuit City had it.
__________________
Brian McCamish
Gresham, Oregon
  #6
Old 04-06-2008, 11:41 PM
Boston Mangler's Avatar
Boston Mangler Boston Mangler is offline
Sponsoring Vendor
Default
Quote:
Originally Posted by targa88
Brian,
I second that! Well done!
__________________
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
  #7
Old 04-06-2008, 11:49 PM
mountainpete's Avatar
mountainpete mountainpete is offline
Super Moderator
Default
Quote:
Very slick setup.
__________________
Pete Hartl - VE6PGH - 
2003 Toyota Tacoma DoubleCab TRD 4x4 - OVRLAND
2008 Subaru Outback Sport - "The Rat"
EXPEDITION = (Encounters + Adventures + Experiences) x YOU
  #8
Old 04-07-2008, 04:20 AM
spressomon's Avatar
spressomon spressomon is offline
Default
Brian,
You're on a roll! Great idea, parts sourcing and install! That would be sooooo nice for aligning the trailer tongue by me-self!
__________________
Life's too short to go without good espresso...
Modded '99 Land Cruiser Hundy for overlanding: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good ear candy, Waeco CF-50, PowerGate with 2nd battery, 9.5XP/Masterpull, VisionX Solstice, OME 864's, Fox 2" remotes with adjustable compression setting at each corner, 12mm body lift, Carl's UCAs, KK SportsRV & KE7NCM.
  #9
Old 04-07-2008, 04:49 AM
Willman's Avatar
Willman Willman is offline
Default
I like it!
Nice work!
__________________
Nic
Sierra Expeditions
www.sierraexpeditions.com
1-866-507-4254
Slightly Modified 2001 Dbl Cab Tacoma
Bantam BT3-C Expedition Trailer
85' FJ60 - New Adventure
  #10
Old 04-07-2008, 05:16 PM
Hltoppr's Avatar
Hltoppr Hltoppr is offline
Overland Certified OC0004
Default
Thanks for doing the write up. I was looking at one last weekend for the Troopy...
Please post your thoughts as to how it continues to work on the road, in inclement weather etc., too!
-H-
__________________
Andrew
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
