delica1994
-This custom designed 1994, 4x4, 2.8 turbo diesel Unibody expedition van is ready to go anywhere you want to go. this vehicle has been mechanically maintained to a high degree. I could not afford to have a break down in areas that i have been exploring. The body has minor dents from bush travel and would be easy to fix.
- Complete replacement of drive train. with used low mileage motor, transmission, differential, transfer case, front suspension, currently @ 80,000 km, also replaced rear suspension, CV joints, ball joints, basically everything in the drive train has been replaced recently. 280,000 km on body.
-It has many custom components that were created specifically for extended expeditions in extreme off road country. It is ready to go to Argentina if you wanted to. This vehicle is made to fit in a shipping container if need be.
- 2.8 liter Turbo Diesel
- Automatic Transmission
- Cruise control
- Air Conditioner
- scratch resistant body paint
- Locking transfer case, 4x4 high, Low and Bull low
- 10,000 Lb winch, can move from the front to the rear if needed to pull backwards or forwards mounted in the 2 inch front receiver
- 3, new 12 volt batteries, one is a deep cycle battery for the refrigerator and 1500 watt inverter
- 2 inverters, 500 watt and 1500 watt
- 2 inch lift
- Old Man EMU rear coil springs, adjustable torsion bar front suspension
- 9 inch LSD rear differential
- Custom steel bumpers with spare tire carrier and steel mesh in the front for maximum cooling and rad protection
- Class 4 towing 2 inch receiver in front and rear.
- K & N Air Filter
- manual locking hubs
- Complete under carriage protection with plate steel including front brake lines and swing arm.
- Custom solar heated roof rack that holds 65 liters of water for dishes, showers, etc.
- Custom roof deck that will support 800lbs plus, i have had 800 lbs up there with 9 full 20 ltr Jerry cans plus a lot of other stuff for expeditions of a few months or more in length.
- 2 water tight roof storage bins
- Custom interior that sleeps 2 with huge 4 foot long drawers. The rear drawer is 15 inches deep, 4x4 in dimension, will hold up to 400lbs. the side drawers hold up to 200lbs each. lots of extra storage as well in 6 foot long side bins for skis, shovels what have you.
- 2 PIAA, 2 KC supper bright halogen lights and 2 fog lights.
- Large steel "puck" locks on all doors if needed.
- New BFG All Terrain Tires
- 3 inch dia. Snorkel with precleaner, drive till it floats!
- 2 inch dia. Steel rocker guards
- Adjustable Pan Hard Rod
- wired for solar panel, I am keeping the original solar panel for my new project.
- In dash DVD,CD movie player, Radio, Ipod player.
- Heavy duty Monroe shocks front and Rancho 5000 in the rear
- Extra set of 5 Yokohama tires mounted on Alloy rims for city use
- Engel Fridge is not included.
The reason i am selling is that i bought a 2 ton 4x4 Mitsubishi Fuso for more space and a traveling studio space.
This van is located in Victoria B.C. Canada for viewing.
for those that are interested in this vehicle. I have a youtube link of the last trip on the North Canol road, Yukon, NWT, extending over a period of 6 weeks from the fall of 2013 here:
https://www.youtube.com/watch?v=sQGFwmcf-BU
- Cruise control
- Air Conditioner
- 2 inch lift
- K & N Air Filter
